JB8
Well-Known Member
I'll keep this short!
Picked up my first 440, cleaning it up, 90% of the lights were burnt out, etc. After replacing the lights I found the signal meter and stereo light to be responsive, but, even with an FM antenna attached I wasn't getting much action for either. Then when I touched the small vertical loop shown in the picture, wowza, the signal meter came to life, stereo light burned steady and bright! What gives? I'm assuming I'm essentially becoming a giant antenna, but why is it so dramatic, and why wouldn't the actual FM antenna work as well? The screw mounts for the antenna are showing some wear and should be further cleaned, but even if I bypass them and touch the antenna legs on the interior of the unit I don't get the same reaction, not even close.
Fun little unit, stoked to get it ship shape, really appreciate any insights you can offer!
