Akprocess
hi, i like the blue lights so thought a 1970s Pioneer would be my next project. Recapped everything but found i could not align the power amplifier on page 12 of the instruction manual TP1 and VR1 only have a range of .6 to 1.2 mv whereas the right channel can be perfectly aligned to 15mv and sounds much better. the potentimeter has a variable range from 1 to 82 ohms like the right side, so i believe it is ok.
the left channel is kind of like an "off channel" radio station - not quite. this is the same for all devices AUX,Phono and FM.
looking at other threads i replaced Q1, Q3, Q5 and Q7 - each one while checking VR1 but no improvement on distortion.
For now i ordered more transistors matching the Equalizer and power amp. Any ideas - generally these problems are something other than replacing transistors. the small caps could be bad but the resistors seem to be in range. thanks for any help, Rich
