jcsul
Member
I've got an SX-550 that has some phono stage issues. After 5-10 minutes (some times a little more or less) one of or both of the channels will drop down to almost nothing. Switching to a different channel (Radio, Tape monitor, Aux) seems to resolve the problem as whatever channel is out will immediately kick back in. A visual inspection of the phono stage looks good. No burt resistors, no leaking or bulging/vented caps. I've gone ahead an ordered replacements for all he PSU, driver, and output transistors to be safe, and also replacements for a general recap.
the reason I'm posting is I'm wondering if anyone has had a similar problem and the culprit have ben the TA7136 that is the IC that does all the Phone pre amplifying. While also looking around online I came across a forum post that lead me to this (http://cimarrontechnology.com/ta7136adapter.aspx) which is a drop in adapter that'll take any jellybean Dip-8 opamp that can handle the voltage the 550 uses in the phono stage (or I could whip up a little regulator for ones that don't) I'm curious if any one has used these adapters in a 550 before and what changes need to be made to the circuitry. If anyone has general advice on what the issue could be outside of a bad cap/transistor, the insight would be greatly appreciated. If Any one needs any testing done to help resolve the issue, I have a DMM but don't have a scope yet. I can take voltage measurements if it will help though.
