Pioneer SX-636 blowing fuses
Sibley
Hi there, I picked up a SX-636 today that ended up having an issue right off the bat. I'm wondering if some of you with some experience could have a look at the schematic that I'm including and tell me if the problem could be the 4 diodes that are all connected. fuse 1 and 5 both blow as soon as its fired up. They don't lead anywhere except the transformer and to these diodes. when I replaced the fuses I had volume and sound from both channels for a split second. Then that fast i did not as i watched the fuses blow. Thanks in advance for any help.
Most likely a blown output, which is drawing too much current and blowing fuses. Remove and test all the output transistors first . Then test everything in the driver amp
First step would be to build a DBT (Dim bulb tester) and use that so that you can prevent the fuses blowing up when you work to get it back working properly.
I actually just purchased a dim bulb tester and I haven't even used it yet. So that will be great to try out.
Have fun with your SX-636 @Sibley !
I still have mine and did a full restore on it back in 2019, with help from here, and it came out great. (It was blowing fuses as well).
