So i purchased all my new caps and the replacement transistor. I was pretty sure i ordered all the right numbers for the transistors:
512-KSC3503DSTU
KSC3503DSTU
NPN Si Transistor x2
512-KSC1845FTA
KSC1845FTA
NPN Epitaxial Sil x4
512-KSA992FBU
KSA992FBU
PNP Epitaxial Sil x6
replacements for 2SC1451, 2SC1344 and 2SA726 respectively.
I started on the amp board and replaced the caps, which i've done a thousand times. Then i replaced the transistors on the board, which i've never done, but after many searches on google, mouser and taking tons of pictures i was cofident that i could install these the right way. Everything out and everything in, I fired up the unit to check my work. No explosions, thats good, but i selected my speaker output and turned up the volume a little and all i heard was a humming, and then a click and nothing. This happened on both channels and then there was nothing coming out of the speakers. i took out all the new transistors and replaced the old ones. still nothing, but if i turn the volume up i can hear music coming from the actual amp board.... this happened to me once before with my Onkyo TX-4500 and i was never able to figure it out. Guys, what have i done? haha
