Rob Wain
Hi. I've used the great info you Gents/Ladies' post here to start the rebuild on my SX-636 and PL-12D turntable. Like most, this was the kit my Dad had when I was a kid (the turntable was his, the amp is beyond repair so I have a new to me unit from eBay).
They both work pretty well, but I started to get popping from the right speaker, intermittently, only lasting a few seconds and no influence from the volume control. I only have cheap Pioneer bookshelf speakers from an old stereo I had in the dining room. The right speaker is now not working.
So I've replaced the two 2SC1451 with ONSEMI KSC3503DTSU and the blown 4amp fuse. I've also replaced all the caps on the power supply board.
All is working as I write, but I have some more parts ready to go in if I need to (including some KSA992 that I've got matched pairs collected together).
I do have 3 questions though:
1) Does DC current gain matter on transistors (I realise it does for differential pairs) ? I'm looking at the power supply, and in particular the 2sd234 for which the KSC2073TU are listed substitutes. However, ONSEMI no longer make these KSC2073TU, but do have KSC2073H2TU. The only difference being the DC current gain (KSC2073TU - 40hFE; KSC2073H2TU - 60hFE).
2) What do people recommend for cleaning the flux off the board after you have installed the new components?
3) What bookshelf speakers should I buy for the system? I would like some period Celestion Ditton speakers (Dad had 44s). However, until I find a reasonably priced pair, I will buy some new speakers to get me up and running again. Looking to spend about £125 max. I cant afford them to be too big, as its all in my home office, and not much room left!
4) I know I said 3, but I thought of another. How do I tell which manufacturer/component is best for audio grade?
Thanks for any advice you can give.
Rob (England)
Rob (England)
