mstewart
Hello, I recently began a recap of my SX-636. I just started working on the power supply which has been recapped with the transistors replaced. I have not changed any diodes. Before I move forward I started measuring voltages and am comparing them to the service manual.
Everything is checking within 1v of the manual with the exception of pin 14. Instead getting 6v I am getting about 13.5 v...the same number I am getting on pin 13. What I can see is that there's a 270 ohm resistor that is between pins 12,13 and 14. So I pulled it just to make sure it checked out and it was fine. So with my limited understanding I'm sort of scratching my head wondering why I'm not getting the 6v at pin 14?
