jacobsteel
I found a decent Pioneer SX-650 at a fleamarket (200 SEK ≈ $20), it wasn't all dead, but had to get service. Now I've given some attention to:
1) Mains switch (opened, oiled/deoxy = stays on solidly, without buzzing sounds now)
2) Lights (changed smaller to LED, larger to new bulbs (might go back to 8V bulbs on the two small, nicer)
3) Cleaned, deoxy, potentiometers, switches, etc.
However, I still had the persistent problem of the Left channel slowly fading down. Cranking up the volume, change song, could revive it to normal sound.
So I started a recap, thanks to this forum I stayed off all Radio capacitors and mainly changed electrolytics on:
Tone Control Assembly (AWG-049)
Power Assembly 1 (GWH-101)
Power Assembly 2 (GWR-101)
Quick-notes on decap:
Good order (taped all caps to a xerox of the schematics, marked all swapped, triple checked polarity).
Forceps (steady, lockable, grip) saved my day, good tools for grabbing tiny caps is essential.
Desoldering braid/wick = less old solder falling on other boards. Check function after each change (less to backtrack if things go south). Time? The above 3 boards, ≈ 30-40 caps ≈ 5 hrs.
BUT - I _still_ have the intermittent problem. Knocking/tapping on Power Assembly GWR-101 can provoke the dropouts, specifically even slight tapping on 2SD313 (both). I did resolder them, but could they have intermittent failure still? I'll try and get some cold spray and change them but questions remain:
1) If I can't get Q7, Q8, 2SD313 x 2 - what are the best replacements?
2) Should I also change Q10, 2SB207?
Thanks a bunch, great forum.
