RFmaster
Member
After doing a recap on a unit do you ever wonder what is removed??? Wonder no more - here is a family portrait of a typical SX-680 recap. In addition to changing electrolytic caps it is highly advisable to R&R noise prone 2SA725, 726 and 2SC1919 transistors in the FM and phono sections. In the power supply 2SD712 and 2SC2073 should be replaced for good measure.. And now for group photos.
Caps
Transistors
2SA725, 726 => KSA992FBU (pin order ECB)
2SC1919 => KSC1845FTA (pin order ECB)
Replacing above transistors quieted FM and Phono sections!!!
In the power supply section
2SD712 => KSC2073TU
2SC1284 => KSC2690AYS - no PCB board modification required leads are small enough.
Recap list can be found here.
http://www.audiokarma.org/forums/index.php?threads/my-attempt-at-a-sx-680-recap-list.489129/
Caps
Transistors
2SD712 => KSC2073TU
