Hello, I found some really valuable info and help here, but I suppose it's time to start my own thread. I'm stuck for 3 days straight and frustrated to the moon.
I got a SX-737 unit with fried transformer (secondary for full wave rectifier, pins 3&4 on the ps board). It's repaired now, but I spotted an issue with bias regulation on power amp board
Left channel - all good. Bias can be adjusted, dc offset too. Voltages on output transistors bases ca. 0.54V
Right channel - can't adjust bias. It regulates between 0-1.1mV.
I changed spv4 to 4x 1n4148 and it widened the range to 3mV
I changed outputs with left channel, no change. Issue stayed it the right. I have +34V and - 34V on filter caps.
Voltage on bad channel output bases vary depending on dc offset - when they're comparable, dc offset is like 80mV or so. Whe offset is set to 0, one base is below 0.5V, other one reaches around 0.65V
I am aware of the idle/offset error in SM
I swapped all 2sa726 and 2sc1451 transistors on the power amp board with recommended ksc's and bd139/140 as drivers, changed Sanyo capsistors to wima foil caps, changed electrolytes, measured 150r, 4r7 and 0r5 resistors, even followed and compared resistor values with SM - pcb looked all original, but there are resistors that don't match with values. So - there should be 3.4V and -3.4V after R39 and R40, I'm getting 0.7V and -1.5V
Resistor No. / installed value / SM value
R39 30k 56k
R40 20k 18k
R41 680r 6.8k
R42 1.8k 5.6k
R43 10k 56k
R44 22k 51k
All of the above were one-leg lifted and measured good.
Voltages on pin 6 and 10 are spot on. 35V and -13V
Grounds are good
Trimpots cleaned and measured good - 100r and 10k
Basically all parts I replaced measured good and replacing them with new substitutes didn't change a thing.
Let me know what info do you need me to provide and I'll do it. Just please help me.
R39 30k 56k
R40 20k 18k
R41 680r 6.8k
R42 1.8k 5.6k
R43 10k 56k
R44 22k 51k
Grounds are good
