Glen, I want to say thanks for all your help so far and also to the other members who have chimed in.
I don't quite understand the test described above both logically and mechanically. If I separate the pre from the main, do I power up with speakers and see if the popping is still there? I assume there would be no input, just amplification. I would need to let it warm up too. Is this correct?
Ok first the logic, The noise you speak of can
potentially be a result of an issue in
"both" the
preamp and
power amp section of the receiver. However much of the time
it's usually one or the other. If you separate the preamp from the amp section and it's still popping over the speakers the way it was, then you know the the noise is being
generated by the power amp section itself. Why? because the preamp is no longer connected to the power amp, and therefore cannot feed any noise into it, which would in turn come over the speakers. Separating the two sections is simply just using the process of elimination, to narrow down the area where the problem really exists.
Next the mechanics,
To start with, the non soldered connections are made to the posts with an old but reliable method called wire wrap.
https://en.wikipedia.org/wiki/Wire_wrap
This method has proven to make reliable connections. However you don't dare unwrap and try to re-wrap it using the same stripped
portion of wire. You won't get a good connection. Also the wire isn't long enough to strip it back to do the connection over. Plus it takes
a special tool to do it right anyway. So then the question becomes, how does one remove a board without messing up the wire wrap?
Well the posts which the wires are wrapped to are just soldered to the PC board. Instead of unwrapping the connections simply un-solder the pin itself
from the board with the wire still attached to it, then you can solder it back when its time to reconnect it.
On the pins, if I de-solder from underneath? Will the wire stay intact with the pin?
Yes, The wire is wrapped tightly, and should be fine provided you don't attempt to unwrap the post.
Lastly, as I put my parts list together, I thought about skipping the mic and the tuner. Should I just replace the two tuner transistors though? If I do that will it need to be aligned?
Unless there is an issue with the tuner relating to them, best to just leave them alone.
