1. Yes the AM antenna is still on the back of my unit.
2. After the cleaning, and as of now I can receive 2 AM stations they very faint.
3. This model pioneer does not have a signal strength meter.
4. Yes I have a dipole antenna connected to the 300 ohm antenna input. (Where is the ohm symbol on my keyboard?)
5. I am not using a coxial antenna.
6. I can receive FM signal and after the cleaning I can receive it quite well. FM seems to be functioning normal except for the fact that stereo is not working. Alignment is also off in other words if I'm listening to 99.9 the needle is on 105.
7. There is no signal strength meter on this model. However the tuning needle does move.
8. Sorry about the confusion with the prior posts I thought the tuning needle and signal meter were the same. Right now the tuning needle will move about 25 percent in each direction and it will center on a strong station.
9.My intention is to get it operational and sell it. I have another one in better condition that I am going to restore. This one however is more of a learning project. With the help of you guys I have already brought it back to life and now I am just working on the radio section. I don't want to send it out for professional alignment because I want to learn how to do it. I don't mind buying test equipment as I have restored receivers in the past and plan on restoring many more in the future. Instead of paying for a professional alignment I would rather take that money and buy more test equipment. ie something that can send a multiplex signal
10. I have the following test gear
Oscilloscope
Function generator
RF signal generator
hand held multimeters (analog and digital)
I also picked up a Elgar Model 121 at a garage sale. It seems to be working good but I don't really now how to use it. It seems to be a very precise and accurate frequency generator that doubles as a variable power supply. It doesn't seem that this has any application in Tuner alignment. However it is something that I can trade or sell to acquire the gear I do need.
I also picked up a ONE AC Line Viewer at at sale. Same thing I can sell or trade this one out for other gear I need.
I also have a Hicock 6000A Tube Tester that I can sell.
Check out all the stuff this guy is selling
https://www.ebay.com/itm/PI-Potomac...=item3d7769db01:g:ND0AAOSwQqZbyPQO:rk:34:pf:0
I'm sure there is some stuff here I need. But if I sell my Elgar I should be able to get one of the newer more high tech signal generators like the HP 8657A. I don't know why I need the HP but I think it has to do with matching the dbm and modulation, plus it seconds as a signal generator and frequency counter.
