sploofer
Member
Hey AKers,
I know there are multiple threads on this topic and I have a pretty good idea what the problem is, but I wanted to get a second opinion before I start working on the solution.
I found this SX-780 earlier this weekend at a flea market. I had no way of testing it at the time, but it was in nice condition and the owner said it worked so I decided to take the $25 gamble. I got home and found that it powered up, all the lights work, the FM and AM VU meter bounces, the source light works, but there was no sound and no relay click.
I opened up the bottom to see if I could find anything problematic (leaks, damage, etc.). The first thing I noticed was that all the fuses were wrapped in aluminum foil and that one of the fuses appeared burnt (see picture below). I read about "the known cold solder joint issue" (http://www.audiokarma.org/forums/index.php?threads/pioneer-sx-780-issue.55876/) so I looked for that and it seems like I have this issue as well (see picture below).
I'm a complete beginner with soldering and repairing, but I think with a little bit of practice I could re-solder the joints. I have a soldering iron, solder and a solder sucker, but I don't have anything else (multi-meter, soldering paste, etc).
I was seriously considering taking this to a shop, but if this is an easy fix, I'd rather spend the money on tools I can reuse and get the experience repairing this unit.
Questions:
https://www.dropbox.com/s/fw38mqc5kowlh0l/20170917_092538.jpg
Close-up of the joints:
https://www.dropbox.com/s/y7v5knyiuscuj2l/20170917_092857.jpg
Close up of the Fuses:
https://www.dropbox.com/s/c2uxwjn5qh0q5d1/20170917_092910.jpg
Questions:
- Why did the previous owner wrap the fuses in foil?
- Should I replace the questionable fuse?
- Should I buy anything else to assist me with this repair or should I re-solder the joints and see if that fixes the problem?
