lebrun53
Hello all,
I have a SX-780 with voltages on the STK-0050 pins that are slightly high.
(This based on other posts here)
Electrolytics on the amp/power board have been changed
Transistors on the amp section all changed per recommendations on other posts here.
Transistors in power supply circuit have been removed, tested and reinstalled.
Voltages from power supply circuit all good.
Here are the voltages on the STK-0050 pins with the power packs removed and the 1k resistors installed.
Left:
Pin 1 -7.81v
Pin 2 -41.16v
Pin 3 -.02v
Pin 8 -.01v
Pin 9 +41.12v
Pin 0 7.78v
Right:
Pin 1 -7.85v
Pin 2 -41.27v
Pin 3 -.01v
Pin 8 -.01v
Pin 9 +41.20v
Pin 0 7.83v
My question is:
Pins 1 & 0 are mentioned to be +- 6v
Is my difference of 1.8v within tolerance?
I have new (clone) power packs ready to install, but wanted to check here for opinions before installing.
What do you Gurus have to say?
(Thank you for being here.... a tremendous resource)
Thanks in advance,
Larry
Left:
Pin 1 -7.81v
Pin 2 -41.16v
Pin 3 -.02v
Pin 8 -.01v
Pin 9 +41.12v
Pin 0 7.78v
Right:
Pin 1 -7.85v
Pin 2 -41.27v
Pin 3 -.01v
Pin 8 -.01v
Pin 9 +41.20v
Pin 0 7.83v
My question is:
Thanks in advance,
Larry
