ikonw8
Thank you all!
I am restoring a Pioneer SX-828. While it's not my first time restoring a receiver, it is my first Pioneer. At this point, all the boards have been re-capped, new semi-conductors on the Main, AF, Head, Protect and Power Supply. The unit operates normally, protect relay engages, sound is excellent. DC Offset is nearly 0 and the bias is 20mv for both channels.
I have a question about the power supply.
What is the normal operating condition for R12 (330 Ohm 2W) resistor on the power supply? This is the one that seems to burn up the PCB. With the tuner enabled, this resistor measures 42v on one side, and 18v on the other side (schematic says 25v). So, this resistor seems to be dissipating about 2.2W. Seems high to me... Is this normal?
Thank you!
Thank you!
