daveyh
Pioneer SX-828 stereo light on and no separation ?? Stereo Lamp FIXED!
I am working on a Pioneer SX-828 receiver and the stereo lamp or light is on all the time. There is also no real nice stereo separation. I have cleaned all the switches with Deoxit. Even if I use the pot switch to change the settings from Mono to stereo or to phono or aux the stereo lamp in still on. It does go a little dimmer if I switch from stereo to Mono but not all the way off. I have recapped most all the boards and even checked the transistors on the driver board, main amp board, protection board and can not find the problem. I also checked the diode D1 and the FM transistor 2SC968 coming off of the lamp to the tuner board #5 connection and both are good. It does have a very light small crackling sound that is very faint coming from the left channel you can hear with the the volume all the way down.
Question?? Could the CA3054 IC on the tuner board be causing the problems or what else could it be?
