Mitchellk
Hello,
I am having an issue with a Pioneer sx-850. R38 and Q6 on the power amplifier assembly is running very hot. So hot you can't touch either within a couple of seconds of turning on the power to the unit. The radio was playing fine when I smelled smoke and found that VR3 had a burn spot on the side of the pot when I pulled the cover. I have used the sx-850 recap lists to recap the power amplifier board and replaced the bias pots and recapped the power supply. I also replaced Q1,Q2,Q3, and Q4 on the amplifier board with KSA940TU and KSC2073TU.
I pulled R38 and it tested at 14.89 on my ohm reading.
This is my first time working on stereos, and would appreciate any help on how to repair this issue. I'd like to save the old girl if possible, and I have printed out the service manuals. I just don't have much experience with this.
