Hi there!
My Pioneer SX-890 is having problems again, this time the problems are a lot bigger. I was listening to it at low volume when there was loud pop and and the relay kicked in. I switched it off quickly just in case and then opened it up and checked the power transistors. Darn it, the 2sb705a for the left channel is shorted between the collector and the emitter! I also checked the 2sa1913 and the 2sa913 for that channel and found the a913 was also shorted between the collector and the emitter.
The question I have is, are there other components that might be shorted or bad, and what would be good replacements for the ones that I've found bad? I know that the b705a is very hard to find genuine.
I checked all the other power transistors and this is what I found:
2sd745a for the left channel: red to base, black to emitter: 524
red to base, black to collector: 521
2sd745a for the right channel: red to base, black to emitter: 522
red to base, black to collector: 518
2sb705a for the right channel: black to base, red to emitter: 478
black to base, red to collector: 449
Everything else was OL.
I did check the bias about a week ago and it was fine, but when I first got it, the bias was too high in the left channel and I had to remove the jumper in order to get the bias where it was supposed to be.
Thanks in advance for any advice
Todd
Todd
