Hi guys, just to update l finished recapping the Pioneer (control amp, main amp, mute and tuner) have not done equalizer yet. I also replaced suspect transistors as described by you all, the main amp actually contained two 2sa809's but l sourced some local replacements. The control amp DID have those four tantalums as pointed out also.
The sound improvement is unexpectedly VERY noticable, the bass is so much more controlled and the mids are back, it also has none of the flatness or "laziness" it had before, it has COMPLETELY transformed the sound and l am not imagining this as l used my other receiver as a before and after reference, they are now very closely matched which is strange as they couldn't be more different in every other way. Thank you to ALL of you for your help, much appreciated. I now know which side of the fence l will be on when it comes to the original vs recapping debate from now on. Now l just have to figure out why the fm tuner lacks sensitivity, works well with a good indoor powered antenna though, the fm didn't work when l bought it so l recapped the board, replaced HA1137 and spent hours re-aligning just using the signal meter, far from ideal l know but l got it all aligned on dial and picking up stations but like l say has to have a good antenna.
