one or both channels?
go to the pre-out / amp in jumpers, phono ground a black dmm lead and probe the red dmm lead into the jumper (one at a time)
with volume turned to zero. see if there is a dc voltage on one or the other.
turn on and off the high/low cut, tone off and -20db buttons while taking readings. tone off, cuts off will read the flat amp output, tone on will read the tone amp output.
a power supply fault could alter the biasing on those boards and actually reverse the needed polarity of the coupling caps.
but you will have to open the unit bottom to read those voltages at the power supply board.
of course if the caps are original, those (c1,c2, c13, c14, c47, c48) are the dreaded CSSA Sanyo sky blue solid aluminum caps - 100% guaranteed failure to short circuits...
Open the bonnet, and the bottom and inspect for them...
