Dawid Ratal
Hello everyone, Have any of you encountered this problem before?
Pioneer SX 950 receiver, serviced. All voltages on the power board are correct. Also the protection plate. No problems with ranges.
Replaced the column switching relay with a new one (Mouser - Omron LY2F-DC24). All switches cleaned (including potentiometers).
But...
After switching on the ampli, the relay clicks turns on only the left channel. However - if I turn it off and on again - all channels play. No problem, and you can listen to music normally.
This happened before the relay was replaced. After replacing it with a new one, it still sometimes won't turn on only the right channel.
Strange situation...
I searched for articles about this, but I didn't see any that had this problem.
The only thing that has not been serviced is the Power Amplifier Board (AWH-050C) - could it be the last one to be the cause?
I will be grateful for valuable tips.
David
But...
David
