Brivan
Well-Known Member
Hi, everyone
I have a Pioneer SX-950 that makes an audible "pop" noise through the speakers when powered off. I have no detectable noises from any of the controls in either the flat amp or preamp. I've read through many threads on AK for a solution to the problem and have implemented some of the fixes with no good results. Here's what I've observed, so far:
Pop noise occurs at the same time (approximately) the relay opens - which is a fraction of a second after power-off.
DC offset on both channels at around 1mV. Idle current at around 20mV.
The popping noise is affected by the volume control.
Removing the pre out/main in jumpers eliminates the popping noise.
Using an audio signal tracer, there is no popping noise from either the tone amp or flat amp.
Removing the audio connection between flat amp and tone amp eliminates the noise (making me think the problem is coming from the flat amp).
Voltage levels measured at the flat amp audio out pins fluctuate to around 5v at power-on and around -5v at power-off.
Things I've done:
Read through a ton of AK posts on this subject!
Replaced Q6 and Q7 on the protection board (even though they tested good).
Replaced R23 12K resistor with a 9.1K resistor and C5 4.7uf 25v capacitor with a 2.2uf capacitor (from an AK post).
Replaced C18 on the power supply board (even though it tested good) (from an AK post).
Replaced C11 & C12 with 4.7uf 50v capacitors on the flat amp (from an AK post).
From what I've done and from the AK posts I've read, the timing of the protection relay opening and the decay of voltage to the flat amp / tone amp section doesn't leave much room for error and the popping noise can likely be a result of things coming out of tolerance in either area. There are some open-ended posts that never did seem to find closure on this problem and I'd be glad to finally post something with steps taken to reach a conclusion but I need a little help, here.
If anyone would be kind-enough to lend their knowledge on this, it would be appreciated!
Things I've done:
