As a machinist, I have gone to SAE for a MM wrench this small with some success. You could try using the .0625 wrench, which is .0035 larger than the 1.5mm, which might tighten enough in your egged hole. Don't use the ball end. you want maximum engagement. LIGHTLY tap the wrench into the hex hole to get tight fit. If it doesn't go in, buff the end of the wrench to remove the anodize, which is typically .0005-.0008 thk, then try again. Let me know how it goes. Other than that, a 1/16 drill bit is your only recourse. I prefer easy-outs to left twist drills. A gunsmith kit typically has the size you need.
