Brivan
Well-Known Member
I recently acquired a Pioneer SX-980 that had a blown main fuse. It turned out the reason for this was two partially-shorted output transistors. One each of the 2SB706 and 2SD746 transistors were bad. I no longer recall where these were physically mounted, but I believe they were both on the rear side of the heat sink when it's installed in the receiver.
After reading some posts on the AK forum, I ordered and installed replacement transistors for all four main outputs: two MJL1302A to replace the two 2SB706 and two MJL3281A to replace the two 2SD746 transistors. I noted the original transistors were configured as BEC and the replacements were BCE and changed wire colors accordingly. I used the original mica insulator between the new transistors and the heat sink.
When checking components on the main amp boards, I found emitter resistor R18 open on the left-hand board. The resistor was replaced. I also went through all power supply voltages with the output transistors disconnected - everything tested good.
Upon reassembly power-up through the DBT, the lamps in the DBT dimmed as normal, but I heard two loud pops from the amp area shortly after. Uh-oh. I found both transistors on the rear of the heatsink had arced to the heat sink at a point where there was a notch in the mica and where a hole in the heat sink was slightly raised. The transistors still checked good, so I used some thermal pads I had in stock to place between the heat sink and transistors - I did this on all four outputs. I also moved the transistors further down and away from the holes in the heat sink (see photo).
I reinstalled everything and applied power, again. it seemed to power up fine, so I measured DC offset at the speaker output terminals and got rail voltage on both left- and right-hand sides. Not good. I double-checked everything and tightened up a loose ground post next to the rear main capacitor. I powered it up, again for more testing and heard more cracking noises from the amp area. Great. I removed the heat sink and output transistors, powered the receiver back up and it seems fine. I checked voltages to the main amp boards and I have +45vdc / -45vdc when connected through the DBT.
That's where I'm at and not sure where to go from here. The output transistors test good, still. Ideas from the masses?
