Brivan
Well-Known Member
I've have a Pioneer SX-980 with erratic DC offset on both channels. I'm able to adjust it so it "centers" around 0v, but it will vary maybe 300mV in either direction. It seems to calm down a little after warm-up, but is still very unstable and might vary as much as 50mV in either direction. Idle current can be set and stays put. Power supply voltages have been checked and are more or less within tolerance.
Additionally, the protection relay engages almost immediately after power-up. Thought it was worth a mention in case it was somehow related to the erratic offset.
The receiver powers up normally when connected to a DBT - bright bulbs for a second, then down to dim. Voltages checked with DBT bypassed.
I've run across one or two of these receivers where the offset voltages wiggles a little, but nothing like this. Would someone have a suggestion as to where I should start looking for the cause?
Thanks!
Thanks!
