Pioneer SX 990.
Went at it cuz the left channel was posting bias readings of 200 plus mvolts. Variable pot makes little difference in bias reading but does adjust
voltage into base of Q6 similar to good channel.
I have tested just about everything in the circuit and replaced a few resistors and C11/C12. All the left channel transistors, the diode, the VRs
seem to test fine. pulled C6 and C8, powered it up with a 60 watt bulb and results were the same. Even voltage drops on transistors look good.
Pulled the outputs {which are fine}. The collector of Q6 reads 800 mv. So with the output transistor voltage drop that gets the bias to 200 mv. Collector of Q7 is
closer to 300 mv and with everything in place, that channel ran proper bias. Right channel read normal bias when everything was hooked up. VRs both sides seem to drop comparable voltage when adjusted and read out 50 ohm resistance range. One thing I noticed was the voltages on the bad channel read a bit lower than the good channel. Chalked this up to higher bias current, but not sure?
At a loss here and really don't want to start replacing everything just to get it up and running. Actually, it does run as it is, but am afraid 200 plus mvs will
fry the one channel and cause a lot of damage. Any suggestions?
