Pioneer SX-990 Left-Channel Static & Muddy
sars
Hi all,
I recently acquired a Pioneer SX990 along with a set of 8ohm monitors & I'm looking for some advice on where to start with diagnostics.
The right & left channels are working on both outputs A & B. The left channel on both outputs (A & B) has a bit of static in the 40% - 70% volume range, this is what I want to diagnose.
Another problem (in both the L & R channels) after some time (1 - 3 min) the sound becomes distorted, almost like it is underwater & muddy (best way I can describe it : )).
When turning the receiver off and on again the distorted sound is gone, only to come back later.
I would appreciate any ideas on what this could be, what to check and where to start?
Background:
- I cleaned all the pots and switches with contact cleaner (I did not disassemble the pots - as I did not want to remove the front plate)
- Cleaned all the terminals and connections that looked like they needed some love.
- I have some electronics knowledge and decent access to tools.
Image of the bottom of the receiver:
I still suspect the problem to be pot related. I'm in the process of properly cleaning the pots and switches. I'll report back.
Next step is transistor and capacitor replacements on the Amp Control board. I found a reliable supplier of Rubycon Capacitors (it's the best I can do in my part of the world).
You are going to want to replace the bias trimmers (VR3 AND VR4, 50 ohms), with new. These will go bad and short your outputs.
