I have this Sx-990 I'm working on for a local record shop . It has a bad channel and the shop owner told me his previous tech did some work on it and it still doesn't work. I removed the amp board and found it had a strange
transistor in it.
Here is the pic. the transistor is an SK 3027 . All transistors are not shorted but measure strange hFE's or I should say very low like 12, 33, 66 and the oddball IIRC was over 100 .
I also found two burnt resistors on that said channel R24 a 22 ohm and R30 a 150 ohm .
Do you think I should change out the outputs with new MJ21194G's ?, the smaller tranny's seem to be fine .
What is that SK 3027 and could it have caused a failure? It does test as an NPN . on my DCA pro 75.
EDIT: Adjustment procedure links .
Athanasios
transistor in it.
Athanasios
