Soundork
Hello,
Before I start, I would like to thank Mark the Fixer for saving me enormous amount of time by creating a BOM.
I am posting, because I need help/guidance through the process of rebuilding a recently purchased SX636. I am going to use this post as a little intro as well, but if you arent interested in reading it, feel free to skip down to the questions section...
I bought the receiver from the local Craigslist. During the email exchanges, the condition of it changed several times...Upon first power up, it took about ten seconds for the sound to come up, then about a minute later a really loud static appeared on the right channel. I turned off immediately, but later that day powered it for a second time and did not hear music, only the loud static. Same after cleaning the controls.
Keep in mind that I am using this as a learning experience, this is also why I am asking so many questions. I have studied the diagrams (to the best of my abilities) and also gone through most if not all posts on the subject.
HERE IS THE INTERESTING SECTION:
I have attached a new BOM that needs vetting. My starting point was Mark the Fixer's BOM and the official one in the repository. Some of the parts on the list are obsolete now and I have proposed new alternatives. Also, in the process I discovered that Nichicon now makes "audio grade" capacitors (I haven't grasped that concept yet, but I am learning). For completion, I also pulled out these numbers even in places where I didnt think they are necessary.
Questions
Equalizer Amp Assembly (AWF-014-0)
1. Why is it ok to switch from electrolytic to a film capacitor for C1/2?
2. C5 and 6 look like power supply filtering capacitors, why not increase their value to 220uF?
3. Confirm that C11/12 do not have to be audio grade capacitors.
4. C13/14 Confirm statement that they don’t have to be electrolytic capacitors
AF Amp Assembly (AWK-035-0)
1. What are the benefits of going non-electrolytic on the coupling input and output of the amplifier i.e. C5/6 and C25/26?
2. C9/10 and 31, confirm benefits of increasing values to 220uf (especially the latter)?
3. C27/28 and 31 Confirm that these don’t have to be audio grade
Power Amp Assembly (AWH-034-0)
1. C1/2 Why film chosen instead of audio grade?
2. Confirm that C7/8 aren’t audio grade.
3. Confirm that should be audio grade capacitors.
Power Supply Assembly (AWR-060-0)
1. I think we get benefits from increasing the values of C6/7/11/14 and possibly C8/13?
Tuner Board (AWE-046-0)
1. C21: Why was a film capacitor used as opposed of an electrolytic like in the AF Amplifier for example?
2. C36: Why was not an electrolytic capacitor used?
3. C48/59/60 Why was this particular type chosen as opposed to the one chosen for the Power Amplifier?
4. C50: Why was not an electrolytic capacitor used? The AF Amplifier used electrolytic.
General Questions:
1. Is it ok to put 0.01uF across all power filtering capacitors to better insulate from the 60Hz hum?
2. Why was the UPW series capacitors chosen for replacement?
3. Mark the Fixer once said in a post that the tuner board should not be removed and I was wondering why.
4. I did go through the switches and potentiometers with the Radio Shack's fluid (which contains DeOxit) and in the process I was unable to remove the speakers A B switches as the screw started to strip. How do I proceed without completely stripping the screw?
5. I also found out the FM Stereo Indicator lamp neatly taped to the chassis. Any ideas why that might be?
Thank you for reading this.
Best
Boris
Questions
General Questions:
Best
Boris
