Pioneer Transistor replacement
Mrcoolest123
hello!
I just got a new piece of gear for my collection, a pioneer sa-710. Got for a nice price because the seller told me it didn't work and wasn't able to repair it. I have some knowledge on electronics so I took it as my project to repair it.
I already found the replacements for the burn diodes and resistors, but I'm unable to find them on my own due to lack of knowledge on the area.
So that's why I am here! What would you guys recommend to replace the following transistors?
2SC2525
2SA1075
2SC2275
2SA985
I found the thread of another guy from 2018 saying he replaced those same pieces with the following, but I searched the web and unfortunately they have been discontinued. hope it helps
2SC2525 —---------- > MG6330-R
2SA1075—---------------> MG9410-R
2SC2275 120v, 1.5A, 25W, 200 MHz, 150 HFE (retain)
2SA985Q 120v, 1.5A, 25w, 180 MHz, 150 HFE (retain)
2SA1075 PNP, 120V, 12A, 7V Vebo, 1.8V Sat, 60-200 HFE, 45 to 60 MHz MJL1302AG PNP, 260V, 15A, 5V Vebo, 75-150 HFE, 30 MHz
2SC2525 NPN, 120V, 12A, 7V Vebo, .7v, 60-200 HFE, 50-80 MHz MJL3281A PNP, 260V, 15A, 5V Vebo, 75-150 HFE, 30 MHz
Thanks friend! I will look in the web to see if I can get these transistors.
Just to know, because I'm no expert, Will it be necessary to make any accommodations on the circuit board to fit them ? Like, will I need to add extra resistors or capacitors to fit the new parts in? Or this is just a case of swapping the old to new ones ?
