Pioneer Turntable
bbow01
I picked up a Pioneer freebie recently. It's a PL-S70 with an Audio Technica DR475LC cartridge. The stylus looks like it's in pretty good shape under a jewelers loupe.
Lot's of plastic in the turntable so I was wondering if it's possible to replace the black plastic base with a custom wood one. I'd take this on as a winter project. Might there be any pitfalls or gains acoustically if I do this?
Thanks,
Brian
I don't know about replacing the plinth but I know that if a plastic plinth is hollow and light, some people beef them up with extra mass underneath, such as plasticine.
The cartridge should be a good one, as the 'LC' means it has a Line Contact stylus. It is difficult to tell how worn a stylus is under a loupe, so you might be wise to replace it. I dare say direct replacements are no longer made by AT but I see that LP Tunes offer this genuine ATN12S stylus with Shibata tip as an alternative.
https://lptunes.com/products/audio-...475lc-dr475lc-cartridge-original-black-stylus
So, it seems that the cartridge is similar to the AT12 for which you should be able to find aftermarket styli, including cheaper ones with an elliptical tip.
I always replace the stylus when I get a used cartridge with an unknown history. A jeweler's loupe can tell if it is dirty, but not worn.
Plasticine (modeler's clay) is useful to stop resonance in plastic shells/plinths.
I'm not familiar with that particular model but it is a mid-80's series. The controls, both electronic and mechanical, are typically component parts of the panel - that iswhat Pioneer calls the upper plinth - the plastic I believe you are alluding to. Not really practical to replace with wood.
If it’s just the aesthetics your trying to change maybe you can put a new plinth around it. Build one out of a wood of your choice. Just a thought
He may very well wish to do that. I've seen it done with other '80s era Pioneer models.
All great info as is the case with AK members. Based on all of your input I'll probably leave it as it, but replace the stylus. Are there any good how-to's on the where and how to add mass to the plinth?
Thanks Again...
Sorry about being naïve on this topic. I am new to the turntable lingo and intricate details of getting good sound out of them. In the distant past I just bought them and plugged them in. I am looking forward to picking up some of the vast store of knowledge on AK as I delve into this new area for me.
Brian
If you're used to 'plug and play' turntables, you should make sure you know how to set up a proper turntable by zero-balancing the arm and then setting the required tracking force and anti-skating. The tracking force is particular to the cartridge or, to be more precise, to the stylus fitted to the cartridge. So you need to find out the correct value to use.
I would encourage you to replace the stylus asap, but if you do start using that Line Contact stylus (and it hasn't yet worn out), it may spoil you and you'll then need to buy an expensive equivalent to get a similar performance. You could, of course, replace the cartridge with something current for which they still make styli. The equivalent model now is probably the AT-VM540ML with MicroLine stylus, which a lot of people like. But if you do replace the cartridge, that will be a whole new adventure :)
I’ve gotten some of my best original styli from those carts sold with “unknown hours, untested” styli!
I never assume a stylus is bad until I’ve cleaned it and tested it. Especially true for high(er) compliance styli that are designed to track at 1.25 grams or less. Many tests have shown that stylus wear increases logarithmically above 1.3 grams VTF. For example, I have nearly new styli for ADC, Empire, Shure, AT, AcuTex, and others. If had taken the conventional wisdom to heart, I would have discarded many perfectly fine styli! Yes, I do test on a record that is not valuable. It only takes seconds to know, once you test for good suspension and set the VTF.
I think the situation is a bit different between a seasoned stylus fanatic (expert?) like yourself Wolfie and someone who is new to turntables (other than 'record players') like the OP. I believe the OP should exercise caution with a used stylus of unknown history. But generally, if a used cartridge is new to you and you don't how it is supposed to sound, it may be difficult to know when it is not sounding quite as it should.
I do have fundamental know how on setting up the player for use, but no where near the expertise that I glean from reading these posts. In the past I've owned several turntables including a Dual 1229. When I bought that one new off a dealers shelf, I took the time to learn how to set up the tone arm and adjust the cartridge alignment (admittedly, I don't recall what cartridge I bought at the time). But, that was many, many years ago. Now I've come full circle (more about that later).
From your posts, I'm at least inclined to invest a little bit in updating the Pioneer turntable with a new stylus. And just live with the shiny plastic aesthetics.
Thanks again...
I think you were being a bit modest about your turntable experience, Brian :)
From the LP Gear page, it would seem that styli for the AT12 cartridge would be suitable. You may be able to find aftermarket versions with different tip profiles (elliptical, hyper-elliptical, shibata) at different costs. Good aftermarket brands are Jico and Tonar, but it may be that Japanese-made styli under different brand names also come from these manufacturers.
...............inclined to invest a little bit in updating the Pioneer turntable with a new stylus. .........
Well that isn't a bad idea, but don't discard the original. Just keep it around. You never know, you might find an opportunity to have it looked at one day. At the very least, you may come a cross a copy of some obscure record that is too worn to expose your new stylus to, but desire to play it now and then regardless. Perfect option for a questionable stylus.
Admittedly, I'm wading into somewhat familiar waters. I'm a gray beard that lived the 78 rpm thru CD's and streaming eras. My first experience with vinyl was as a very young lad listening to my grandpas collection (when he wasn't around as we lived in his house with my Mom and Dad and three sisters growing up). Soon after it was listening to 45's on my buddy's sisters "record player". Then, as a teenager, I somehow got a hold of my own record player and began borrowing (from the local library) and buying 33 rpm vinyl. From there it was a progression to turn table, receiver, speakers and my vinyl collection grew. But, of course, I followed the logical progression to 8 track in the car, reel to reel (TEAC, but I don't remember the model), cassette player and eventually CD player and the Internet, etc. All the while, most of my vinyl collection languished in the basement. (At one cringeworthy point I set a stack of vinyl nearly three feet high on the curb for the garbage collector. My CD collection was growing and I had no vision of some future where I would sadly regret my hastiness.)
So, on to Napster, iTunes and you know the like.... I thought I was in heaven. But here I am, eons later staring wistfully at my current paltry vinyl collection of about 60 records. My CD collection though is at an all-time high. (I am still buying "collectible" CD's on a popular resale site.) Anyway, here's how I got here. (And sorry for my long winded back story that probably comes off like a James Michener novel.) After retiring, I found some extra time and plunged into the nostalgia rabbit hole when I scarfed up a non working McIntosh MC250 recently off a local resale site. It now sits on my work bench all torn apart as I work through the repair process. This little foray gave me the idea to dust off the Pioneer turntable that I was given and pair it with a yet-to-be-determined pre amp and the MC250 as an "analog" alternative to my AV Rx and CD player that, along with a HDTV, forms the core of my Audio/Video entertainment.
So I can have a foot in both analog and digital worlds so to speak. I just hope that I don't have to take out a second mortgage when I, like zillions of others, figure out that the ritual of cellophane cracking, carefully sliding out pristine vinyl and mounting it to the turntable and becoming engaged in rapture while reading liner notes and being transported by the music, is still more fulfilling that sliding plastic into a tray or tapping the screen on a smart phone.
