Pioneer v. Monster Cable.
Ken Kelly
The Electric Warrior.
Hello All,
Has anyone discovered an adapter for the Pioneer speaker terminals that will accept monster cable? Thanks for reading!
if you like destroying the jacks with a huge force lever - pin plugs work.
However, I would simply use the correct gauge wire, strip and tin it to prevent fraying and short circuits - and enjoy the tunes.
In my opinion, unless the receiver or amp was designed for use with large wire, don't.
Thanks, Jordan. What gauge do these terminals take? Or do I use lamp cord? Thanks for answering.
be honest with you, I have never really read a lot of good reviews on the Monster cable. I have been researching it to determine my final cable and monster cable has always come up as an average cable.......
I am going to try that diy Cat5 cable here in a bit as I have read quite a few good things about it and for now, basically costs nothing(I have a ton of it lying around)
I do believe that Pioneer dropped the ball on a whole lot of their speaker binders and am looking into replacing most of mine
Just wondering, how do you do this.
Eric
Tinning is where you simply take the bare wire and apply a little solder to it so as to avoid stray strands that could short out.
Monster (and others) made screw on adapters that looked like banana plugs but then had gold (or tinned) wires coming out of them. I figure the less connections you have the more direct the signal path (and that's a good thing). IMHO Monster is all about profit margin. I was at a Monster sponsored party at a CES show years ago and that was their primary focus.
I modded my KR-9600 to have binding posts but then that's just me.
JimB
JimB
Thanks for the info. I hate when the wire gets frayed so I think I'll do this.
Speaker terminals on a PIONEER SX-770 (slits)
On a related question. I bought the above recently and it has a vertical and a horizontal slit for each speaker. What is the secret to getting a good connection with the speaker wire? I can slide it in the slits (I think the vertical is positive) but it is subject to sliding back out. Are you supposed to insert the wire with a small screwdriver or something to get the bindings inside the slit to "grab" the wire? thanks!
