The PL-518 uses a particle board base, I don't know if I would qualify that as "wood."
I am starting to lean more towards Pioneer TT's lately. I like the way they are made and what they are made from.
PL-550, PL-518..
SL-1700, SL-1301..
They are a little more Vintage ..The wood sounds better IMO.
Thanks,
John.![]()
OK, I am checking my 1st statement...
Simulated wood material kind of soaks up or dampens the vibrations.
The metal has a ringing effect I noticed. I will try and spray something on it to dampen the sound.
Could just be because I finished (2) Pioneers back to back...:scratch2:
Thanks,
John.![]()
Thanks,
John.![]()
It is " simulated wood ".![]()
There's a reason the vast majority of speakers are built from MDF (or some similar sort of substance) instead of wood: as you suggest, it dampens vibration very effectively.
I do have a question, though... how loud are you listening to music if you're hearing mechanical feedback transduced from the audio waves back through your system to produce a ringing sound? Or is your turntable sitting on top of your speaker?
