toads
Hello. I posted this in two incorrect spots first so hopefully I found the right board lol
I own a Pioneer VSX-501 that was given to me by my uncle years ago. I use it in my living room for television audio and as a general purpose multimedia player and it's worked well for many years but over the last year or so I've noticed an odd occurrence. When the receiver has been playing music or movie audio for an hour or so it sounds like the top end of the sound intermittently cuts out on BOTH channels with multiple inputs (I've noticed it on phono as well as cd and TV inputs). I can still hear the song or movie or whatever but the top end just cuts out and returns when it wants.. it seems to be temporarily fixed by cranking the volume all the way up for a second but that solution has become less and less effective over time.
It's not the worst problem but since I'm somewhat handy with a soldering iron and know how to read electrical drawings (more or less) I figured if it was something easily seen with the naked eye like a bad solder connection or something I could fix it myself but.. after looking at just about every solder connection I could see without removing all the ribbon cables (since that is a huge pain as is) and tearing it apart, the solder joints look good. At this point I am thinking there may be a bad capacitor or transistor(? Maybe? Those can go bad, right?). So I downloaded the service manual from archive.org and started scratching my head..
I'm thinking since it's happening on both channels it could perhaps be something to do with the Audio Function Assembly or maybe the Power Supply Assembly. Or maybe even the Volume assembly! There are a ton of things to look at and I'm not sure where to start diagnosing x_x. I thought I could tackle this alone but I may be in slightly over my head. But this is also very interesting to me and I'm excited to learn more. If anyone has any troubleshooting advice I'd be very appreciative! I hope I don't just have to end up putting new capacitors in the whole thing or something
Side view of receiver. Board closest to viewer and to the right is the Tuner, I believe. The one directly behind it with the two ribbon cables going over the top is the Audio Function Assembly.
I believe this is the Amp Assembly(?)
Also here underneath the front speaker terminals.. probably should have moved that out of the way when I was taking this picture but I didn't think about it.
