One step at a time. There's a reason Mark wanted you to troubleshoot by powering up with the BALANCE over to one side or the other (minimizes or grounds the other channel signal at that point, effectively only allowing one channel to work, basically 1/2 the load vs both channels and full load @ 4ohms). Do the Cold startup on the 4Ω speaker and let it run on ONE CHANNEL (L or R). See if it trips itself at about 10 minutes or so. Report back results. It may take a week or so. DON'T get ahead, and have 77.3 things running around in your head. "What if's" will trip you up everytime.
GO SLOW, Work the problem, Fix it. THEN do the overhaul. BTDT with a 1010. (Damn near gave MTF a heart attack when I did mine, but he Gibb's slapped me a couple times and it apparently took.
) There's really good guys here, so listen to them and don't run off 1/2 cocked.
Seen too many times on AK, in the last 15 years where someone has a problem with a 1010, and gets ahead of himself the guys here trying to help going in 5 directions at the same time. It don't end well for the 1010 and the guy quits in the middle. It's a couple of orders of magnitude HARDER to visualize the problem when the unit is across country behind firewall.
SLOW DOWN!!! Patience, Grasshopper. It's gonna take time, LOGICAL THINKING (sometimes it's harder when your 27 vs 67), and staying on course. Take pictures of each board (before and after, with replacements listed) and we can usually tell you if you either missed something or installed something backwards.
Time for a complete synopsis, BOARD BY BOARD.
Identify the board, and list each part replaced (Q1, C3, R47, etc) along with it's replacement that you have done. Do this vertically, One part per line. Identify the board by it's part #
Then detail the exact problem, (without getting the 1250 involved as it just confuses us old folks sometimes). Who, what, where, when, How.
What is connected to the 1010 (phono, tape deck, etc.) preferably no sources connected. Just the speakers and an antenna if needed for FM/AM work. Settings on all controls, time after cold start up after 2 days, did you flip or turn any controls, change channels on FM/AM(probably not likely but lets cover all the bases).
Bias L/R
OFFSET L/R
WALL VOLTAGE xxxVAC
List the Power Supply voltages vertically by pin # with + and - for Pos/Neg voltages and AC or DC (ie: +35vDC, -13vDC, 7.8vAC, etc.)
This is NOT going to be an overnight fix. It's gonna be slow, sometimes tedious, other times it seems boring as hell, but stick to one thing at a time and it'll get done faster and RIGHT!
Larry
