Hello Pioneer Guru's! I am seeking some advice on my Sx-1280. One of my pre-amp boards will not adjust into spec for the DC offset. The "lowest" I can get it is -1.1V. That is with the VR turned all the way clockwise. The other pre-amp board will adjust no problem. I have replaced all the transistors on both boards, and even replaced the 979 transistors with matched 992's. I have been comparing voltages across the good and bad boards and it seems that the bad board has been very consistent with being about .7 - .9 volts off on the 733, 945, 608, and 628 transistors compared to the good side except on Q4 and Q5. My Q4 & Q5 voltages are as follows:
Good Board Bad Board Good Board Bad Board
Q4: Q4: Q5: Q5:
B = +78V B = +78V B = -76V B = -76V
C = +2.2V C = +.9V C = -2.2V C = -3V
E= +78V E = +78V E= - 76 E = -76
My question is what would cause such an imbalance at these transistors? I have also replaced a couple of the diodes on the bad board with 4148's to see if they were an issue and no change. Every transistor is new, most diodes except the varistors are new, and all resistor values match exactly to the good board and yet it still won't get into spec! I am at a loss here and could really use some help from the guys who know what they are doing Ha!. Any suggestions would be appreciated! Thanks for your time.
Q4: Q4: Q5: Q5:
