PL-115D, DIN connection? Replacement?
greenflash
Hi AK, I just bought online a PL-115D turntable (good deal) but it's missing the power cable (that should be easy fix) and .. instead of the usual RCA cable I see a .. DIN terminal? Photo below.
Is there a way to easily replace that? So that I can get a normal RCA output + ground. Thanks!
Easiest is to replace the whole cord with a rca vdeo cord. Just take the bottom off and work underneath.
Thanks @Tucker99 I believe that's the best option, RCA cable + ground. Getting the adapter might be a real pain. I just talked to a technician who could do that for me if I don't figure it out.
