PL-530 cartridge alignment
V65008
Member
What alignment protractor should be used to align my Pioneer PL-530? It has an ADC headshell with an ADC XLM mark II cartridge. I see on vinylengine.com there are several protractors that can be printed off. Also, LPgear.com sells a plastic protractor. Is it trial and error of the different methods to get the best performance?
Good morning, I'm not certain what overhang alignment Pioneer use, but I use Baerwald with excellent results on three different turntables using the 'typical' two point protractors made by Shure and Ortofon, which conform to Baerwald overhang alignment.
This article may be useful as a guide to proper use of a two point protractor. http://www.mds975.co.uk/Content/vinyl07.html Regards, Felix aka catman.
49 mm from the back of the gasket to the tip of the stylus .. square in the headshell.
Correct. Keep the cartridge square in the headshell. Here is a more graphical representation:
You can use any of the protractors if you like, but often they push the cartridge so far forward in the headshell that you might run out of slot room. Important: You use either Pioneer's diagram or a protractor--not both. They will not coincide with each other or confirm each other. Both are correct, but use different geometry.
Thanks for the all the advice and links. Since the headshell and cartridge are not Pioneer, I will use the Barewald method.
I'll second that "thanks" for all of the advice! I recently purchased a PL-530, and will soon be changing carts - this post was invaluable!
What a great forum :thmbsp:
Please tell me if I am wrong, but I think the make of either cart or headshell doesn't have to do with the overhang, the distance from the base of the headshell to the tip remains...
You are not wrong.
Pioneer uses the manufacturer's short cut of 49 mm for the S tone arm. :music:
You certainly can... but the headshell and cartridge make are irrelevant, it's the relationship between the bayonet connector (end of your arm) and the stylus itself that should be at 49mm. A trip to a hardware store should produce a small machinist's rule with a sliding 'T'/pocket clip, whereas you can set it to 49mm and easily line things up. I've found that with Pioneer turntables using 49mm, this is a lot faster and, in most cases, more accurate than using a protractor.
Posting to a decade old thread! I added a Goldring E3 to my PL-530 and finally finished the alignment, thanks to some help from you all! Table is sounding great, thanks!
When I had my PL-530 I used a Mobile Fidelity GeoDisc to align a Grado Black and it worked perfectly. No IGD and very nice playback of any records. Worked like a charm.
