goldfish
Hi all, long time reader, first time poster.
I have a Pioneer PL-540 that I picked up for cheap a while ago, hoping I could nurse it back to health. The motor works, but the speed isn't right. Auto-return and bearings are fine. There are also some cosmetic issues: a broken tonearm rest, a burnt out strobe, and rotted rubber in the feet.
I had the internals looked at by someone I trust, and he told me someone had clearly tried to fix it in the past, and... well, they gooched it. Namely:
- some assembly screws are missing or the wood holes are stripped
- the regulation board support posts are cracked
- oscillator board had several wires cut and sloppily re-soldered back onto the (wire-wrap) posts
- the IC chip on that board is an aftermarket chip, and there's a blob of solder on several of the terminals
- the internal speed trims are fully advanced to compensate for the erratic speed
- some caps have been replaced (I'll take internal pictures when I pick it back up later this week)
I'd love to give this turntable a new life, and learn a bit in the process. I'm not an electronics expert, but I'm handy and have time to learn. The question is, is it worth it? Or should I just bite the bullet and part this one out? I know the ICs in particular are made of unobtanium, but oscillator boards must show up every once in a while? Any advice or opinions you all have would be greatly appreciated. Thanks!
