PL-55X turntable runaway...
What can have happened??? I recapped the boards and after that it runs at 200rpm. I put the old caps back and still got the runaway. I was very careful to orientate the caps properly and have examined the board many times for dropped solder etc., nothing wrong. I will get the schematic soonest and if anybody can provide it I’ll bee grateful.
/Goran
So, it sounds like the speed sensor isn't sensing, if that makes sense. On the earlier models, there was a pickup head that sensed magnetic pulses imbedded into the platter's inside rim. I assume the X55 series used the same technique.
I'd be looking for it to be readjusted or might have been moved during the rebuild process, including the connects it makes to the controller board.
You didn't do anything like wipe down the platter with solvent did you?.....
Cheers,
David
dshoaf,
There is no sensor on this model. it locks into the 50/60 Hz of the line voltage. You may have a defective component on the one of the boards.
Ron
I have bought the service manual, but it seems I have to wait for it. I was hoping to have my PL-55X in order for Christmas, so, does anyone maybe have a manual available for instant download?
/Goran
I found the failing component! It was a resistor with a broken leg. Very odd fail I think. I did not break it and you usually have to bend a leg many times to break it. Anyway, I got a working PL-55X again :banana: .
/Goran
Had the same problem in my Fender Dual Showman. Had it recapped 5 years ago with Sprag ATOMs in the power supply. 6 months ago, one of the legs just FELL OFF the dang capacitor. I thought these were top-shelf parts!
