renault4
Hello,
I have a set of Magnepan 1.7i speakers on order and I'm thinking ahead on placement.
I'm starting with an empty room (PDF attached). I intend to use the Maggies only in a two-channel system, but they will need to share the room with a 55" LCD run through a Definitive Technology sound bar and an SW--with a couch and armchairs. The room is about 20.5ft x 19ft (see attachment); wall A is likely where the TV will go, and I understand that having a TV and associated furniture in between speakers is less desirable, wall B is a mix of wall and glass sliding doors (no drapes), but strangely the best chance of symmetry, wall C is an 8ft wall with one side wall while open on the other. The whole room is carpeted with 9ft ceilings.
Any thoughts? setups to absolutely avoid? Thanks in advance!
