Hi Guys,
I just purchased a HVT754 planet audio hybrid tube amp for my car. I have started it up to test it and it was draining 2.6 amps on idle, which I thought was high even with 4 x 12ax7 tubes in it (they should use approx 600mA for the heaters) I took off the case and checked all the outputs with a multimeter and they seemed fine, but when I power it up there is a 1 ohm resister before the speaker connection that is getting hot. Its only on one channel and the corresponding output transistor doesn't get warm. Note that there is nothing connected to the amp while I was testing. Does anyone have an insight of what could be happening, any help is greatly appreciated.
