TrevorBarten
Well-Known Member
It's obvious someone has already done something to the turntable. It looks like it has been converted from 110v to 220v but am not sure. The soldering looks somewhat poorly done which would lead me to believe someone who's inexperienced worked on this. Is there any quick test I can run to see what's wrong ? Or are there any obvious flaws in the wiring you guys can spot ? I wouldn't mind getting it repaired if need be, but a new motor would probably not be worth it. (Not to mention I can replace that myself anyhow). Another thing of note would be that the strobe light is on even if it's on off. It becomes brighter once turned on. I don't think this is originally supposed to be like that.
