Hi,
This one is baffling me a bit so I thought I'd ask the experts...
I have a Pioneer PL-514 which I acquired recently. The platter is rubbing on the black metal plate directly underneath.
After a bit of investigation i came to the conclusion that I must have faulty main bearing spindle or platter.
I purchased another main spindle and bearing to try and it was the same.
Then I found a platter for this turntable and tried that; still the same.
So, two different spindles, two different platters and it is still rubbing.
Any ideas??
I cant imagine the black plate is bent out of shape and I don't think the metal base plate that the bearing attaches to is out of shape either.
I was thinking of getting a slightly bigger ball bearing to raise the spindle but then that's going to put other things out of alignment.
Anyway, any help much appreciated with this annoying problem!
Regards,
Any ideas??
Regards,
