Please Advise
Status
Not open for further replies.
PROJECT 2501
I decided to set up an old pioneer SA-1050 integrated that I had tucked away for a while. I planned to use my smart phone as the source with a 3.5mm TRS to RCA cable patched in to the AUX of the integrated. After set up was completed i powered on. Relays clicked in without delay so I pressed play on the youtube app on my phone while the volume dial was at zero. ....
Now, i instantly noticed that when I turned up the dial, the woofers on my Technics SB-7000a's sucked up into the baskets and as soon as I took my hand off of the dial the woofers reset to normal positioning. Naturally, I grabbed the dial and turned the volume back down. The woofers in a direct response to the volume dial pushed outward this time.....
Whats going on???
What I was trying to subtly say is....you are only allowed to ask the same question in just ONE subforum.
Rule #4
Specific Rules
  1. Don’t insult others, or engage in name-calling.
  2. 'Thread-crapping' (meaning disrespecting the topic or intention of the thread or forum) is not allowed.
  3. 'Spamming' results in immediate and permanent banning.
  4. Post in the one best forum for your topic; one thread per topic, no duplicates.
Unbelievable. .... Are you for real?
Im having difficulty understanding the reason why you would even remotely care about what im writing let alone go out of your way to enforce rules like some cafeteria hall monitor when neither the topic of discussion or the matter of regulating obedience have anything to do with you. What, are you bored or something?
BTW.
You should carefully re-read rule number two from the list of rules that you were so helpful in providing me with.
Status
