Please Help Me Choose Filter Capacitors Kenwood KR-6600
gort69
AK Subscriber
Hi folks -
I will be replacing the filter caps in my KR-6600 and will be ordering from Mouser. The originals are 8200uf 56V, but there seems to be a better selection in 63V. I need the 35mm diameter to fit the original clamps.
In the following link from Mouser, only the first 5 listed are in stock, and would prefer to choose from those. Would be very interested in the rationale for your choice, as I'm not certain which spec I should be looking at.
http://www.mouser.com/Passive-Compo...yc4mb&Keyword=electrolytic+capacitors&FS=True
Thanks very much for any help!
Open your search parameters to also allow 80V caps and the selection nearly doubles with the same case diameter and lead spacing.
http://www.mouser.com/Passive-Compo...tic+capacitors&Ns=Voltage+Rating+DC|1&FS=True
IMO, for power supply filtering a higher ESR is not an issue, and the variation in the available parts is negligible anyway.
Generally, higher insulation voltage is seldom an issue other than it can result in a larger package with higher cost.
Of the pieces in the selection table, I might choose this one http://www.mouser.com/ProductDetail...=sGAEpiMZZMtZ1n0r9vR22eVOVN2I0zMFq6KW3YgdImI= primarily becasue with all other ratings being relatively equal it has the lowest rated ripple current.
