jhoyt
Incomprehensible space llama
Disconnect the speaker terminals, and do a resistance check on the speaker drivers. Infinite and zero are both very bad. You should see somewhere from 4 to 8 ohms, although I don't remember what the original drivers specs were. But if you're in that ballpark, you're probably OK. The level controls may be dirty as well. I had a similar pair with that very problem.
Good luck with your move, it's never fun (for me, at least). I can definitely understand paring down the stable in anticipation of moving!
