sonci
Well-Known Member
Ok, I searched for weeks Audiokarma, trying to fix it by myself, but the beast just stays in protection, so I'm starting this thread.
It happened when I tried to set the idle current, the trimpot went open, maybe because I had sprayed it with Deoxit, there was a puff, smoke and protection kicked in.
Even though there was a bad smell I didn't see anything burnt on the pcb. The manual seems too complicated so I had to measure everything, and there are a lot of components on this amplifier.
Of course the output transistors of one channel were blown, a pair of Toshiba 2SD1148 and 2SB863, also I identified 3 burned resistors.
R516
R522
R528
the transistors Q516, Q518, Q520,Q522,
2SD1148 I used ONsemi NJW0281G
2SB863 I used ONsemi NJW0302G , as recommended here on a similar thread. The trimpot was Vr502, it measures ok now.
I replaced resistors and transistors but nothing has changed, it stays in protection. The voltages between transistors legs seem identical for the equal pairs.
I have read that in dynamic super A amplifier with blown output, the chip IC 502 (vc5022-2), can be damaged too, but when I test it with multimeter in diode mode, it measures the same as the other chip.
There are no technician for this kind of work near me, and I really want to fix it, since this was my fault.
Any help?
R516
R522
R528
Any help?
