MichaelNee
Hello,
I'm new in the whole vinyl thing and bought myself a lenco L65 with HEA9000 amp at a local garage sale for 40 euro's.
Everything was working fine for a few weeks but now I have a problem with the right channel.
The right channel is super silent and it's on all the inputs (phono, FM, ...) and I've managed to rule out some things:
So I tought it was a speaker thing at first because I bought 2 Technics SB-660 speakers that were as good as new, still in the box. (those are 8ohm and 70watts I guess)
The thing is when I connect my headphones to either one of the two inputs on the amp, the right side is almost inaudible. When I only listen with my right ear, I can hear some music but playing with volume doesn't change much and balance doesn't either.
The connections that hold the fuses were a little bit black (like burnt or something) So I went on and cleaned the connections a little and change the fuses for the left and right channel, still no solution.
Also playing with the buttons and selecting mono or phono, balanced or LS1 or 2or anything doesn't change it.
What's also strange is when I power on the unit I get a little poof on both sides of my headphones. And when turning it off, I hear like radio channel static left and right, going down in volume until completely off.
I've now desoldered the Turntable to take a closer look but all the transistors and caps seem just fine.
Can you guys help me out with this since the setup sounded really great, for that little money, I don't want to be buying new gear...
I've attached some photos and a schematic, which I cannot read btw
THANKS A LOT!!!!
THANKS A LOT!!!!
