Please help to identify original Tannoy red driver or repeared?
As I remember in the trade, any treatment on a paper cone will make the cone heavier.
Tannoy cones were vacuum pressed and air dried. They could easily vary 1 gram between finished examples.
More important concerns are paper degradation and appearance.
My Tannoys are stored in a dry warehouse, and whilst not as valuable as these, I would presume that humidity/dampness would also affect the weight and hence the sound?
I do remember a particular pair of GRF's (autograph) that we sold in the very early 70's, - fantastic.
3300 usd is my limit for now...so i should chose go for SRM 15..or buy this Red 12....
I never have a possibility to compare SRM and Red...but heared that for vocal, jazz RED are better than SRM. Is that true?
The thing about humidity is they should be effected equally.
Speakers definitely sound different depending on humidity.
Lots of companies used phenolic cones in marine/ high humidity locations.
Also for same money I can buy SRM 15 (photo enclosed). Can you give some suggestions how sound of SRM 15 and red 12 will vary?
You'd probably want to update the crossover on those ceramic-magnet K-series Tannoys. The original design wasn't exactly (or even close to) optimal.
